Versioni del software di controllo RosettaCNC
RosettaCNC dispone di tre versioni del Software di Controllo NC:
- STD, ovvero Standard. Versione gratuita con l'interfaccia utente standard di RosettaCNC.
- PPH, ovvero interfaccia utente per PanelPC RoesttaCNC, o computers con monitor Touch capacitivo FullHD orizontale. Il software è licenziato tramite DONGLE USB acquistabile tramite email: contact@rosettacnc.com
- PPV, ovvero interfaccia utente per PanelPC RoesttaCNC, o computers con monitor Touch capacitivo FullHD varticale. Il software è licenziato tramite DONGLE USB acquistabile tramite email: contact@rosettacnc.com
- STD:
- PPH:
- PPV:
Changelog versione STD 1.12.1 vs 1.11.1
- Added Quick Support with Rust Desk.
- Added Spindle Analog Output Mode management.
- Added Spindle Cooling System Pump management.
- Added Axis/Spindle Manual and Automatic lubrication management.
- Added G100 P8 command for programmatic Axis/Spindle lubrication management.
- Added new Alarms & Warning messages for Axis/Spindle Lube and Plasma Torch.
- Added Customized G-Command G250 to add a fixed offset to axes' origin.
- Added Customized G-Command G390 to probing X/Y/Z stock origin with 3D Probe.
- Added Documentation of customized G/M commands as Italian PDF.
- Added new named parameters:
- #<cnc.scan.laser.offset_x>
- #<cnc.scan.laser.offset_y>
- #<cnc.scan.laser.offset_z>
- #<cnc.scan.laser.center_distance>
- Added Jog Space Stop Mode management for UI Jog commands.
- Added Korean translation.
- Added translation panel information to the language panel selection.
- Updated API Server to version 1.4.
- Updated Python to version 3.11.3, with add/update of related packages.
- Removed request of timed-license when NC board is not available.
- Imporved UI interface:
- Added program window resize checking to avoid sizes below 1024x768 pixels.
- Added Scan Management & Plasma Monitoring pages in control bar.
- Changed default view at strartup from Work to Override sheet.
- Improved Alarms/Warnings view panel look to better read alarm/warning code and text.
- Removed use of scan_digital.stl for probe scanning, substituted by probe tool settings.
- Improved Plasma Torch management:
- THC management totally remade with new features.
- Added new settings:
- General: Torch Probe Input Mode
- General: Torch Arc Ok Input Mode
- General: Torch Anti-Collision Input Mode
- General: During Cutting the Torch Probe Input Can Act as Extra Torch Anti-Collision Input
- Internal THC: THC Regulation Mode
- Internal THC: Torch Arc Voltage-Autoacquiring Space
- Internal THC: THC Max Regulation Velocity
- Internal THC: THC Min Regulation Velocity
- Internal THC: THC Regulation Band A
- Internal THC: THC Regulation Band B
- Internal Max Regulation Time in Band A
- Increased Torch Voltage analog input sample time.
- Fixed G100 P6 Timeout for Torch Arc Ok Input check.
- Improved performance of reading geometry files.
- Improved Scan 3D management with UI restyle and new functions and settings.
- Improved External Program management adding PYTHON to use custom Python with console window.
- Improved checking of board settings changes.
- Improved translations engine.
- Improved texts and Italian translations.
- Improved installation of 64-bit version so that with OS < Windows8, Python will not be installed.
- Fixed Tools Library and Setup ATC changes check management.
- Fixed disappear of M109/M120 modal dialog when the Control Software is iconized.
- Fixed PC Is Connected management to avoid false state during NC setup.
- Fixed "Homing: Deceleration Space" value calculation.
- Fixed 3D Virtual Machine ugly visualization after a view restoring.
- Added new firmware 1.74.
- Added Scan 3D management.
- Added Work Plasma page tailored for systems with THC Internal mode enabled.
- Added global or machine modifiable ui-dark.xml & ui-light.xml theme file for Dark & Light mode.
- Added automatic scrolling for NC messages and errors when text is wider than available space.
- Added missing expression evaluator in Tools Library editor data fields.
- Improved button text when wider than available space.
- Fixed the ugly virtual machine look after a page change.
- Fixed missing tool info visualization when NC is SCAN 3D state.
- Improved Jog which touch buttons management and features.
NOTE
Le versioni STD/PPH e PPV sono normalmente sempre ALLINEATE tra loro.
Le funzionalità presenti nella STD sono disponibili anche in PPH e PPV, sebbene su quest'ultime due vengano
rappresentate a livello interfaccia operatore in modo diverso.
Per questo specifico rilascio la versione PPV non continene ancora l'interfaccia UI alle seguenti funzionalità:
- Scansione 3D di superfici e piano.
- Interfaccia evoluta di supporto alla modalità PLASMA con THC interna.
