Eccomi con l'output dei comandi
[4294667.296000] Linux version 2.6.15-magma (root@ubuntu) (gcc version 4.0.3 (Ubuntu 4.0.3-1ubuntu5)) #1 Fri Jun 9 20:51:19 EEST 2006
[4294667.296000] BIOS-provided physical RAM map:
[4294667.296000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[4294667.296000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[4294667.296000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[4294667.296000] BIOS-e820: 0000000000100000 - 000000000fffc000 (usable)
[4294667.296000] BIOS-e820: 000000000fffc000 - 000000000ffff000 (ACPI data)
[4294667.296000] BIOS-e820: 000000000ffff000 - 0000000010000000 (ACPI NVS)
[4294667.296000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[4294667.296000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[4294667.296000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[4294667.296000] 255MB LOWMEM available.
[4294667.296000] On node 0 totalpages: 65532
[4294667.296000] DMA zone: 4096 pages, LIFO batch:0
[4294667.296000] DMA32 zone: 0 pages, LIFO batch:0
[4294667.296000] Normal zone: 61436 pages, LIFO batch:15
[4294667.296000] HighMem zone: 0 pages, LIFO batch:0
[4294667.296000] DMI 2.3 present.
[4294667.296000] Allocating PCI resources starting at 20000000 (gap: 10000000:eec00000)
[4294667.296000] Built 1 zonelists
[4294667.296000] Kernel command line: root=/dev/hdb1 ro quiet splash
[4294667.296000] Initializing CPU#0
[4294667.296000] PID hash table entries: 1024 (order: 10, 16384 bytes)
[ 0.000000] Detected 1535.887 MHz processor.
[ 16.686754] Using tsc for high-res timesource
[ 16.686768] I-pipe 1.3-00: pipeline enabled.
[ 16.687596] Console: colour VGA+ 80x25
[ 16.688127] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 16.688536] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 16.696897] Memory: 249632k/262128k available (1619k kernel code, 11932k reserved, 493k data, 220k init, 0k highmem)
[ 16.696902] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 16.756029] Calibrating delay using timer specific routine.. 3073.36 BogoMIPS (lpj=1536681)
[ 16.756068] Security Framework v1.0.0 initialized
[ 16.756076] SELinux: Disabled at boot.
[ 16.756092] Mount-cache hash table entries: 512
[ 16.756218] CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
[ 16.756226] CPU: After vendor identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
[ 16.756235] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 16.756238] CPU: L2 Cache: 256K (64 bytes/line)
[ 16.756240] CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000020 00000000 00000000 00000000
[ 16.756258] mtrr: v2.0 (20020519)
[ 16.756262] CPU: AMD Athlon(TM) XP 1800+ stepping 02
[ 16.756266] Enabling fast FPU save and restore... done.
[ 16.756269] Enabling unmasked SIMD FPU exception support... done.
[ 16.756274] Checking 'hlt' instruction... OK.
[ 16.760257] checking if image is initramfs... it is
[ 17.442060] Freeing initrd memory: 6690k freed
[ 17.453810] NET: Registered protocol family 16
[ 17.453843] EISA bus registered
[ 17.454477] PCI: PCI BIOS revision 2.10 entry at 0xf17e0, last bus=1
[ 17.454487] PCI: Using configuration type 1
[ 17.455009] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 17.455020] PnPBIOS: Scanning system for PnP BIOS support...
[ 17.455079] PnPBIOS: Found PnP BIOS installation structure at 0xc00f9a40
[ 17.455083] PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0x9a70, dseg 0xf0000
[ 17.455638] PnPBIOS: 15 nodes reported by PnP BIOS; 15 recorded by driver
[ 17.455662] PCI: Probing PCI hardware
[ 17.455667] PCI: Probing PCI hardware (bus 00)
[ 17.456322] Boot video device is 0000:01:00.0
[ 17.456772] PCI: Using IRQ router VIA [1106/3147] at 0000:00:11.0
[ 17.461000] pnp: 00:11: ioport range 0x290-0x297 has been reserved
[ 17.461004] pnp: 00:11: ioport range 0x3f0-0x3f1 has been reserved
[ 17.461008] pnp: 00:11: ioport range 0xe400-0xe47f has been reserved
[ 17.461011] pnp: 00:11: ioport range 0xec00-0xec3f has been reserved
[ 17.461221] PCI: Bridge: 0000:00:01.0
[ 17.461224] IO window: d000-dfff
[ 17.461229] MEM window: df000000-dfdfffff
[ 17.461234] PREFETCH window: dff00000-fbffffff
[ 17.461250] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 17.461713] audit: initializing netlink socket (disabled)
[ 17.461724] audit(1171988686.793:1): initialized
[ 17.461833] VFS: Disk quotas dquot_6.5.1
[ 17.461877] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 17.461943] Initializing Cryptographic API
[ 17.461949] io scheduler noop registered
[ 17.461954] io scheduler anticipatory registered
[ 17.461959] io scheduler deadline registered
[ 17.461969] io scheduler cfq registered
[ 17.462096] isapnp: Scanning for PnP cards...
[ 17.818117] isapnp: No Plug & Play device found
[ 17.833342] PNP: PS/2 Controller [PNP0303,PNP0f13] at 0x60,0x64 irq 1,12
[ 17.835084] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 17.835355] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 17.835360] Serial: 8250/16550 driver $Revision: 1.90 $ 48 ports, IRQ sharing enabled
[ 17.835539] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 17.835642] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 17.837549] 00:02: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 17.837741] 00:03: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 17.838347] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 17.838412] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 17.838417] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 17.838634] mice: PS/2 mouse device common for all mice
[ 17.839052] EISA: Probing bus 0 at eisa.0
[ 17.839087] EISA: Detected 0 cards.
[ 17.839137] NET: Registered protocol family 2
[ 17.847266] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 17.847435] TCP established hash table entries: 16384 (order: 4, 65536 bytes)
[ 17.847566] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 17.847704] TCP: Hash tables configured (established 16384 bind 16384)
[ 17.847707] TCP reno registered
[ 17.847785] TCP bic registered
[ 17.847791] NET: Registered protocol family 1
[ 17.847797] NET: Registered protocol family 8
[ 17.847800] NET: Registered protocol family 20
[ 17.847820] Using IPI Shortcut mode
[ 17.847858] Freeing unused kernel memory: 220k freed
[ 17.865067] input: AT Translated Set 2 keyboard as /class/input/input0
[ 17.903527] vga16fb: initializing
[ 17.903534] vga16fb: mapped to 0xc00a0000
[ 18.000135] Console: switching to colour frame buffer device 80x25
[ 18.000141] fb0: VGA16 VGA frame buffer device
[ 19.803777] VP_IDE: IDE controller at PCI slot 0000:00:11.1
[ 19.803807] VP_IDE: chipset revision 6
[ 19.803811] VP_IDE: not 100% native mode: will probe irqs later
[ 19.803824] VP_IDE: VIA vt8233a (rev 00) IDE UDMA133 controller on pci0000:00:11.1
[ 19.803836] ide0: BM-DMA at 0x9800-0x9807, BIOS settings: hda:DMA, hdb:DMA
[ 19.803855] ide1: BM-DMA at 0x9808-0x980f, BIOS settings: hdc:DMA, hdd:DMA
[ 19.803866] Probing IDE interface ide0...
[ 20.188387] hda: Maxtor 6Y060L0, ATA DISK drive
[ 20.442957] hdb: QUANTUM FIREBALLP AS20.5, ATA DISK drive
[ 20.494432] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 20.494487] Probing IDE interface ide1...
[ 21.286546] hdc: LITE-ON LTR-32123S, ATAPI CD/DVD-ROM drive
[ 21.999354] hdd: LTN526, ATAPI CD/DVD-ROM drive
[ 22.051700] ide1 at 0x170-0x177,0x376 on irq 15
[ 22.058872] hda: max request size: 128KiB
[ 22.079493] hda: 120103200 sectors (61492 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(133)
[ 22.080036] hda: cache flushes supported
[ 22.080103] hda: hda1 hda2 < hda5 >
[ 22.099420] hdb: max request size: 128KiB
[ 22.106779] hdb: 40132503 sectors (20547 MB) w/1902KiB Cache, CHS=39813/16/63, UDMA(100)
[ 22.106785] hdb: cache flushes not supported
[ 22.106806] hdb: hdb1 hdb2 < hdb5 >
[ 22.141157] hdc: ATAPI 40X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
[ 22.141170] Uniform CD-ROM driver Revision: 3.20
[ 22.156535] hdd: ATAPI 52X CD-ROM drive, 120kB Cache, UDMA(33)
[ 22.650824] usbcore: registered new driver usbfs
[ 22.650854] usbcore: registered new driver hub
[ 22.676607] USB Universal Host Controller Interface driver v2.3
[ 22.676667] PCI: Found IRQ 5 for device 0000:00:09.0
[ 22.676675] IRQ routing conflict for 0000:00:09.0, have irq 9, want irq 5
[ 22.676701] uhci_hcd 0000:00:09.0: UHCI Host Controller
[ 22.677049] uhci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 1
[ 22.677061] uhci_hcd 0000:00:09.0: irq 9, io base 0x0000b400
[ 22.677214] hub 1-0:1.0: USB hub found
[ 22.677227] hub 1-0:1.0: 2 ports detected
[ 22.778085] PCI: Found IRQ 5 for device 0000:00:09.1
[ 22.778097] IRQ routing conflict for 0000:00:09.1, have irq 11, want irq 5
[ 22.778105] IRQ routing conflict for 0000:00:0d.0, have irq 11, want irq 5
[ 22.778114] IRQ routing conflict for 0000:01:00.0, have irq 11, want irq 5
[ 22.778128] uhci_hcd 0000:00:09.1: UHCI Host Controller
[ 22.778166] uhci_hcd 0000:00:09.1: new USB bus registered, assigned bus number 2
[ 22.778178] uhci_hcd 0000:00:09.1: irq 11, io base 0x0000b000
[ 22.778297] hub 2-0:1.0: USB hub found
[ 22.778307] hub 2-0:1.0: 2 ports detected
[ 22.878840] PCI: Found IRQ 10 for device 0000:00:11.2
[ 22.878850] IRQ routing conflict for 0000:00:11.2, have irq 9, want irq 10
[ 22.878855] IRQ routing conflict for 0000:00:11.3, have irq 9, want irq 10
[ 22.878868] uhci_hcd 0000:00:11.2: UHCI Host Controller
[ 22.878899] uhci_hcd 0000:00:11.2: new USB bus registered, assigned bus number 3
[ 22.878905] uhci_hcd 0000:00:11.2: irq 9, io base 0x00009400
[ 22.879002] hub 3-0:1.0: USB hub found
[ 22.879012] hub 3-0:1.0: 2 ports detected
[ 22.879241] PCI: Found IRQ 10 for device 0000:00:09.2
[ 22.879248] PCI: Sharing IRQ 10 with 0000:00:05.0
[ 22.879284] ehci_hcd 0000:00:09.2: EHCI Host Controller
[ 22.979671] PCI: Found IRQ 10 for device 0000:00:11.3
[ 22.979681] IRQ routing conflict for 0000:00:11.2, have irq 9, want irq 10
[ 22.979685] IRQ routing conflict for 0000:00:11.3, have irq 9, want irq 10
[ 22.979699] uhci_hcd 0000:00:11.3: UHCI Host Controller
[ 22.979730] uhci_hcd 0000:00:11.3: new USB bus registered, assigned bus number 4
[ 22.979736] uhci_hcd 0000:00:11.3: irq 9, io base 0x00009000
[ 22.979834] hub 4-0:1.0: USB hub found
[ 22.979845] hub 4-0:1.0: 2 ports detected
[ 23.083140] ehci_hcd 0000:00:09.2: new USB bus registered, assigned bus number 5
[ 23.083157] ehci_hcd 0000:00:09.2: irq 10, io mem 0xde800000
[ 23.083169] ehci_hcd 0000:00:09.2: USB 2.0 started, EHCI 0.95, driver 10 Dec 2004
[ 23.083271] hub 5-0:1.0: USB hub found
[ 23.083286] hub 5-0:1.0: 4 ports detected
[ 23.285627] kjournald starting. Commit interval 5 seconds
[ 23.285643] EXT3-fs: mounted filesystem with ordered data mode.
[ 30.970217] Linux agpgart interface v0.101 (c) Dave Jones
[ 31.124466] agpgart: Detected VIA KT266/KY266x/KT333 chipset
[ 31.126699] agpgart: AGP aperture is 32M @ 0xfc000000
[ 31.171652] PCI: Found IRQ 10 for device 0000:00:05.0
[ 31.171669] PCI: Sharing IRQ 10 with 0000:00:09.2
[ 31.338401] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 31.366294] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 31.700957] Floppy drive(s): fd0 is 1.44M
[ 31.715924] FDC 0 is a post-1991 82077
[ 31.725438] Real Time Clock Driver v1.12
[ 31.794056] irda_init()
[ 31.794086] NET: Registered protocol family 23
[ 31.965387] input: ImPS/2 Generic Wheel Mouse as /class/input/input1
[ 32.073539] 8139too Fast Ethernet driver 0.9.27
[ 32.073587] PCI: Found IRQ 9 for device 0000:00:0f.0
[ 32.073603] IRQ routing conflict for 0000:00:0f.0, have irq 5, want irq 9
[ 32.073939] eth0: RealTek RTL8139 at 0xd0986000, 00:0e:e8:f2:3a:3e, IRQ 5
[ 32.073942] eth0: Identified 8139 chip type 'RTL-8100B/8139D'
[ 32.127300] 8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
[ 32.419159] input: PC Speaker as /class/input/input2
[ 32.658400] ts: Compaq touchscreen protocol output
[ 32.755917] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 33.266958] lp: driver loaded but no devices found
[ 33.543457] Adding 746980k swap on /dev/hdb5. Priority:-1 extents:1 across:746980k
[ 34.712028] EXT3 FS on hdb1, internal journal
[ 35.203189] md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
[ 35.203194] md: bitmap version 4.39
[ 35.725145] device-mapper: 4.4.0-ioctl (2005-01-12) initialised:
dm-devel@redhat.com
[ 40.230170] NET: Registered protocol family 10
[ 40.230324] lo: Disabled Privacy Extensions
[ 40.230518] IPv6 over IPv4 tunneling driver
[ 42.632533] cdrom: open failed.
[ 43.021790] cdrom: open failed.
[ 49.603822] cdrom: open failed.
[ 50.329882] eth0: no IPv6 routers present
[ 51.799813] NET: Registered protocol family 17
[ 62.476620] [drm] Initialized drm 1.0.1 20051102
[ 62.486472] PCI: Found IRQ 5 for device 0000:01:00.0
[ 62.486485] IRQ routing conflict for 0000:00:09.1, have irq 11, want irq 5
[ 62.486494] IRQ routing conflict for 0000:00:0d.0, have irq 11, want irq 5
[ 62.486502] IRQ routing conflict for 0000:01:00.0, have irq 11, want irq 5
[ 62.486587] [drm] Initialized radeon 1.24.0 20060225 on minor 0
[ 63.384160] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[ 63.384182] agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
[ 63.384230] agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
[ 63.524384] ppdev: user-space parallel port driver
[ 63.749113] [drm] Setting GART location based on new memory map
[ 63.749126] [drm] Loading R200 Microcode
[ 63.749168] [drm] writeback test succeeded in 1 usecs
[ 64.322150] Bluetooth: Core ver 2.8
[ 64.322157] NET: Registered protocol family 31
[ 64.322159] Bluetooth: HCI device and connection manager initialized
[ 64.322174] Bluetooth: HCI socket layer initialized
[ 64.370917] Bluetooth: L2CAP ver 2.8
[ 64.370923] Bluetooth: L2CAP socket layer initialized
[ 64.384598] Bluetooth: RFCOMM socket layer initialized
[ 64.384619] Bluetooth: RFCOMM TTY layer initialized
[ 64.384622] Bluetooth: RFCOMM ver 1.7
[ 103.465702] spurious 8259A interrupt: IRQ7.
o@aaa:~$ lsmod
Module Size Used by
rfcomm 32280 0
l2cap 18948 5 rfcomm
bluetooth 39012 4 rfcomm,l2cap
ppdev 6916 0
radeon 111136 1
drm 61972 2 radeon
af_packet 16136 0
ipv6 229888 6
dm_mod 48696 1
md_mod 58964 0
lp 9028 0
tsdev 5952 0
pcspkr 1796 0
8139cp 17536 0
i2c_viapro 7316 0
i2c_core 16272 1 i2c_viapro
8139too 21632 0
via_ircc 23572 0
mii 4608 2 8139cp,8139too
irda 169404 1 via_ircc
serio_raw 5636 0
rtc 9908 0
floppy 55716 0
psmouse 32516 0
crc_ccitt 1920 1 irda
shpchp 38208 0
pci_hotplug 23220 1 shpchp
parport 29640 2 ppdev,lp
snd_cmipci 28960 3
gameport 11144 1 snd_cmipci
snd_pcm_oss 46880 0
snd_mixer_oss 15360 1 snd_pcm_oss
via_agp 7424 1
snd_pcm 72072 3 snd_cmipci,snd_pcm_oss
snd_page_alloc 8072 1 snd_pcm
snd_opl3_lib 8320 1 snd_cmipci
snd_timer 19716 3 snd_pcm,snd_opl3_lib
snd_hwdep 6688 1 snd_opl3_lib
snd_mpu401_uart 5888 1 snd_cmipci
snd_rawmidi 19488 1 snd_mpu401_uart
snd_seq_device 6796 2 snd_opl3_lib,snd_rawmidi
snd 41316 14 snd_cmipci,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_opl3_lib,snd_timer,snd_hwdep,snd_mpu401_uart,snd_rawmidi,snd_seq_device
soundcore 7008 1 snd
agpgart 27208 2 drm,via_agp
evdev 7424 1
ext3 117512 1
jbd 45332 1 ext3
ide_generic 1152 0
ehci_hcd 25736 0
uhci_hcd 28688 0
usbcore 105732 3 ehci_hcd,uhci_hcd
ide_cd 27780 0
cdrom 34848 1 ide_cd
ide_disk 14080 4
via82cxxx 8452 0 [permanent]
generic 4356 0
vga16fb 12040 1
cfbcopyarea 3840 1 vga16fb
vgastate 9472 1 vga16fb
cfbimgblt 2944 1 vga16fb
cfbfillrect 3840 1 vga16fb
fbcon 38432 72
tileblit 2304 1 fbcon
font 7936 1 fbcon
bitblit 5376 1 fbcon
softcursor 1664 1 bitblit
o@aaa:~$
