avrei individuato questo Kit
Costo circa 320 euro + qlc di dogana
Frame: Threaded rod( parts and components)
Structure:Acrylic sheet
Print Size:210*200*180mm(Max)
Layer thickness:0.1-0.4mm
LCD screen: Yes (Support )
XY axis positioning accuracy:0.012mm
Z axis positioning accuracy:0.004mm
Nozlle diameter:0.4mm(standard configuration)
Nozlle temperature:170oC-275oC
Platform temperature:110oC (adjustable)
Platform material:aluminium plate
Printing material:PLA, ABS, HIPS
Material diameter:1.75mm
Software language:English
File format:STL,G-code
Machine dimension:430*405*370mm
Package dimension:480*430*26mm
Power supply:DC 12V
OS:XP,WIN7,MAC
Host computer software:Repetier-Host
Environmental requirement:Temp: -5 - 40°c,Humidity:20-70%
Che ne dite? Fa schifo?
Ale
