Richiamare cartella siemens 840C
jimmy83
Messaggio da jimmy83 » sabato 16 agosto 2014, 17:25
Salve a tutti lavoro su una hyundai spt-h500s con controllo Siemens 840c,la macchina ha due pallet e per abbinare i due pallet uso questo programma:
%MPF1
(CONTROLLO PALET 2 PRONTO)
G58Z0
N4@714
N5@381R1K1K8K1
N6@714
N7@121R1K1K-4
N8 L72
L1001
(CONTROLLO PALET 1 PRONTO)
N9@714
N10@381R1K1K8K1
N11@714
N12@121R1K1K-9
N13 L71
(CONTROLLO LUCE PALET SPENTA)
N14@714
N15@381R1K1K8K1
N16@714
N17@121R1K0K18
N18 L855
@100K-4
M30
e questi sono 2 esempi di programmi:
%SPF855
(TIPO5/462 PGM PINCIPALE)
N5 T1 L6 H5 (RICCIO D50)
N10 G0G90B0
N15 L860(RIF)
N20 L801(PGM ESEGUE ATTACCCO)
N25 G0G91B-85
N30 G90
N40 G0G90B275
N50 L861(RIF)
N60 L802 (PGM ESEGUE PIANO X INSERTI)
N70 G0G91B-3
N80 G90
N85 G0G90B272
N90 L863(RIF)
N100 L803 (PGM ESEGUE SEDE INSERTI)
N110 G0G91B-2
N115 G90
N118 G0G90B270
N120 L864(RIF)
N130 L810 (PGM ESEGUE ALTEZZA 120)
N140 T5 L6 H32 (FRESA D25)
N150 G0G90B275
N160 L861(RIF)
N170 L804 (PGM ESEGUE SPACCO 30.25 SGROSS)
N180 T32 L6 H9 (FRESA D10)
N190 G0G90B275
N200 L861 (RIF)
N210 L807 (PGM ESEGUE SPACCO 15.3)
N220 T9 L6 H8 (FRESA D15/16)
N230 G0G90B275
N235 L861 (RIF)
N240 L805 (PGM ESEGUE SEDI INSERTI FIN)
N245 G0G90B0
N250 L860 (RIF)
N260 L806 (PGM ESEGUE ATTACCCO FINITURA)
M9M5
N270 T8 L6 H6 (PUNTA D26)
N275 G0G90B0
N280 L860 (RIF)
N290 L808 (PGM ESEGUE FORI 26)
N295 T6 L6 H1 (SMUSSATORE)
N300 G0G90B0
N305 L860 (RIF)
N310 L809 (SMUSSI)
M9M5
M17
%SPF1001
(BELL PRG PRINCIPALE)
N10 T1 L6 H31
N15 G0G90 B90
N20 L1003 (RIF)
N30 L1011 (ESEUE PIANO 90 GRADI)
N31 G0G91B-90
N32 G90
N33 G0G90B0
N35 L1004 (RIF)
N40 L1012 (ESEGUE PIANO SU FORO)
N50 G0G90B270
N60 L1007 (RIF)
N70 L1011 (ESEUE PIANO 90 GRADI)
N90 G0G91B-90
G90
N100 G0G90B180
N105 L1008 (RIF)
N95 L1012 (ESEGUE PIANO SU FORO)
M9
N100 T31 L6 H5 (PUNTA D44)
N105 G0G90B180
N110 L1008 (RIF)
N115 L1014 (ESEGUE FORO 44)
N120 G0G90B0
N125 L1004 (RIF)
N130 L1014 (ESEGUE FORO 44)
M9
N135 T5 L6 H28 (FRESA D25)
N140 G0G90B0
N145 L1004 (RIF)
N150 L1015 (ESEGUE D45.5)
N155 G0G90B180
N160 L1008 (RIF)
N165 L1015 (ESEGUE D45.5)
M9
N170 T28 L6 H10 (SMUSSATORE )
N175 G0G90B180
N180 L1008 (RIF)
N185 L1019 (ESEGUE SMUSSO)
N190 G0G90B0
N195 L1004 (RIF)
N200 L1019 (ESEGUE SMUSSO)
M9
N205 T10 L6 H30 (FRESA D32 R5)
N210 G0G90B90
N220 L1006 (RIF)
N225 L1013 (ESEGUE RAGGIO 5)
N230 G0G90B270
N235 L1010 (RIF)
N240 L1013 (ESEGUE RAGGIO 5)
M9
N245 T30 L6 H29 (PUNTA D12)
N250 G0G90B270
N255 L1010 (RIF)
N260 L1016 (ESEGUE PREFORO D12)
N265 G0G90B90
N270 L1006 (RIF)
N275 L1016 (ESEGUE PREFORO D12)
M9
N280 T29 L6 H27 (PUNTA D12.5)
N285 G0G90B90
N290 L1006 (RIF)
N295 L1017 (ESEGUE FORO D12.5)
N300 G0G90B270
N305 L1010 (RIF)
N310 L1017 (ESEGUE FORO D12.5)
M9
N315 T27 L6 H1 (PUNTA D16)
N320 G0G90B356
N325 L1005 (RIF)
N330 L1018 (ESEGUE FORO D16
N335 G0G90B174
N340 L1009 (RIF)
N345 L1018 (ESEGUE FORO D16)
G0G90B0 M9M5
G90
M01
M17
(RIF)=RIFERIMENTO
Attualmente creo i miei programmi nella cartella Utente/LOCAL/(es)T5462 in ogni cartella ho un programma MPF1 come quello postato e vari sottoprogrammi (SPF).
Il mio problema è quando devo abbinare due programmi che sono in cartelle differenti, devo copiare tutti i sottoprogrammi in un unica cartella. Volevo sapere se era possibile richiamare la cartella senza dover copiare ogni i volta i sottoprogrammi. Grazie
ciro.postiglione
Re: Richiamare cartella siemens 840C
Messaggio da ciro.postiglione » domenica 19 ottobre 2014, 13:01
Non so se hai gia risolto ma ti posto la soluzione " forse", nel CN 840C c'è una directory che si c, in quella chiama STANDARD puoi copiarci tutti i file che ti occorrono sempre, è una directory che viene letta all'accensione del CN.
Quindi una volta copiati i file spegni il CN e riaccendilo , verifica e fammi sapere.
jimmy83
Messaggio da jimmy83 » martedì 28 ottobre 2014, 17:38
Non ho trovato la cartella STANDARD ci sono GLOBAL-LOCAL-NCK. L'unica cartella STANDARD è nel menù Servizi ma non penso sia quella che mi dici tu.
ciro.postiglione
Messaggio da ciro.postiglione » sabato 1 novembre 2014, 20:12
solitamente sotto LOCAL, dove hai anche le cartelle dei file di lavoro, strano che all accensione lui non ti dica che manchi la cartella.
prova a crearla inserisci i file che ti servono e riavvia il CN.
sotto la cartella NCK vedi i file attivi e dovresti trovarci quelli che hai caricato nella cartella standard, se è cosi allora sta funzionando
se vuoi altre info puoi anche chiamarmi quando sei davanti al CN
saluti
jimmy83
Messaggio da jimmy83 » martedì 9 dicembre 2014, 20:34
Ciao Ciro, io volevo evitare di copiare i tutti i file nella stessa cartella, adesso uso il tasto sel prog e carico la cartella con i file che mi servono, volevo evitare dei doppioni non è proprio possibile richiamare la cartella in LOCAL. Grazie
Torna a “Siemens”
