Il mio dubbio e' anche capire MKB cosa fa con i registri intco1 e intcon0 quando usa la macro ADC_read(2).
Qualcuno ha esperienze a proposito?
Allego il listato:
program adc2_lcd
' * Project name:
' adconlcd
' * Copyright:
' © mikroElektronika, 2005 - 2006
' * Revision History:
' 20050312:
' - initial release.
' * Description:
' This code demonstrates how to use library function ADC_read, and library
' procedures and functions for LCD display (4 bit interface)
' * Test configuration:
' MCU: PIC16F877A
' Dev.Board:
' Oscillator: HS, 4.000 MHz
' Ext. Modules: None
' SW: mikroBasic v5.0 or higher
' * NOTES:
' - If you are using EasyPIC4, use provided jumper on top right to connect potentiometer to RA2
dim ch1 as byte
ch2 as byte
t1 as word
t2 as word
Text1 as char[17]
Text2 as char[17]
tlong1 as longint
tlong2 as longint
main:
PORTB =0 ' clear portb
TRISB =0 ' designate portb as output (LCD is connected to portb)
intcon =0 ' disable all interrupts
Lcd_Init(PORTB) ' initialize (4-bit interface connection)
Lcd_Cmd( LCD_CURSOR_OFF) ' send command to LCD (cursor off)
Lcd_Cmd(LCD_CLEAR) ' send command to LCD (clear LCD)
Text1 ="A/D Aduri" ' assign text to string a
Lcd_Out(1,1, Text1) ' print string a on LCD, 1st row, 1st column
Text2 ="Prova" ' assign text to string a
Lcd_Out(2,1, Text2) ' print string a on LCD, 2nd row, 1st column
OPTION_REG = $80
ADCON1 = $82 ' configure VDD as Vref, and analog channels
TRISA = $FF ' designate porta as input
Delay_ms(2000)
Text1 = "voltage1:" ' assign text to string a
Lcd_Out(1,1,Text1) ' print string a on LCD, 2nd row, 1st column
Lcd_Chr(1,14,"V")
Text2 = "voltage2:" ' assign text to string a
Lcd_Out(2,1,Text2) ' print string a on LCD, 2nd row, 1st column
Lcd_Chr(2,14,"V")
while true
t1 = ADC_read(1) ' get ADC value from 1st channel
tlong1 = t1*5000
t1 = tlong1 >> 10
ch1 = t1 div 1000 ' prepare value for diplay
Lcd_Chr(1,11,48+ch1) ' write ASCII at first row, 9th column
Lcd_Chr(1,12,".")
ch1 = (t1 div 100) mod 10
Lcd_Chr(1,13,48+ch1)
ch1 = (t1 div 10) mod 10
Lcd_Chr(1,14,48+ch1)
ch1 = t1 mod 10
Lcd_Chr(1,15,48+ch1)
delay_ms(1)
t2 = ADC_read(2) ' get ADC value from 2nd channel
tlong2 = t2*5000
t2 = tlong2 >> 10
ch2 = t2 div 1000 ' prepare value for diplay
Lcd_Chr(2,11,48+ch2) ' write ASCII at 2nd row, 9th column
Lcd_Chr(2,12,".")
ch2 = (t2 div 100) mod 10
Lcd_Chr(2,13,48+ch2)
ch2 = (t2 div 10) mod 10
Lcd_Chr(2,14,48+ch2)
ch2 = t2 mod 10
Lcd_Chr(2,15,48+ch2)
delay_ms(1)
wend
end.
Cordiali saluti
