Gantry 300mm X 300mm X 110mm compact con ARDUINO e GRBL
Re: Gantry 300mm X 300mm X 110mm compact con ARDUINO e GRBL
- walgri
Grazie per la condivisione Turbina !
- progress
Questo è GRBL ultima versione, cioè la 0.9g, come macchine oltre la GENERIC c'è la SHERLINE_5400, la SHAPEOKO, la SHAPEOKO_2 , la ZEN_TOOLWORKS_7x7 e la OXCNC, ho aggiunto la mia CREOSTAMP con le impostazioni della mia nel file defaults.h
#ifdef DEFAULTS_CREOSTAMP
// Grbl generic default settings. Should work across different machines.
#define DEFAULT_X_STEPS_PER_MM 100.0
#define DEFAULT_Y_STEPS_PER_MM 100.0
#define DEFAULT_Z_STEPS_PER_MM 100.0
#define DEFAULT_X_MAX_RATE 1500.0 // mm/min
#define DEFAULT_Y_MAX_RATE 1500.0 // mm/min
#define DEFAULT_Z_MAX_RATE 1500.0 // mm/min
#define DEFAULT_X_ACCELERATION (100.0*60*60) // 10*60*60 mm/min^2 = 10 mm/sec^2
#define DEFAULT_Y_ACCELERATION (100.0*60*60) // 10*60*60 mm/min^2 = 10 mm/sec^2
#define DEFAULT_Z_ACCELERATION (100.0*60*60) // 10*60*60 mm/min^2 = 10 mm/sec^2
#define DEFAULT_X_MAX_TRAVEL 300.0 // mm
#define DEFAULT_Y_MAX_TRAVEL 300.0 // mm
#define DEFAULT_Z_MAX_TRAVEL 110.0 // mm
#define DEFAULT_STEP_PULSE_MICROSECONDS 10
#define DEFAULT_STEPPING_INVERT_MASK 7
#define DEFAULT_DIRECTION_INVERT_MASK ((1<<Y_AXIS)|(1<<Z_AXIS)) //0
#define DEFAULT_STEPPER_IDLE_LOCK_TIME 25 // msec (0-254, 255 keeps steppers enabled)
#define DEFAULT_STATUS_REPORT_MASK ((BITFLAG_RT_STATUS_MACHINE_POSITION)|(BITFLAG_RT_STATUS_WORK_POSITION)) //15
#define DEFAULT_JUNCTION_DEVIATION 0.02 // mm
#define DEFAULT_ARC_TOLERANCE 0.002 // mm
#define DEFAULT_REPORT_INCHES 0 // false
#define DEFAULT_AUTO_START 1 // true
#define DEFAULT_INVERT_ST_ENABLE 0 // false step enable invert
#define DEFAULT_INVERT_LIMIT_PINS 1 // false limit pins invert
#define DEFAULT_SOFT_LIMIT_ENABLE 0 // false
#define DEFAULT_HARD_LIMIT_ENABLE 1 // true
#define DEFAULT_HOMING_ENABLE 1 // false
#define DEFAULT_HOMING_DIR_MASK 3 // move positive dir 3
#define DEFAULT_HOMING_FEED_RATE 25.0 // mm/min
#define DEFAULT_HOMING_SEEK_RATE 500.0 // mm/min
#define DEFAULT_HOMING_DEBOUNCE_DELAY 250 // msec (0-65k)
#define DEFAULT_HOMING_PULLOFF 2.0 // mm
#endif
nel file config.h bisogna selezionare la propria macchina:
// Default settings. Used when resetting EEPROM. Change to desired name in defaults.h
//#define DEFAULTS_GENERIC
#define DEFAULTS_CREOSTAMP
#endif
GRBL ideato da
Copyright (c) 2009-2011 Simen Svale Skogsrud
GRBL fino alla 0.8
Copyright (c) 2011-2013 Sungeun K. Jeon
GRBL 0.9
I parametri della macchina , area di lavoro , passo viti etc... sono memorizzati nella eerom di arduino, è possibile cambiare questi parametri senza ricompilare e ricaricare, quì ci sono i comandi che si possono inviare mediante la seriale ( la porta usb) mediante i programmi jcnc o UniversalGcodeSender o altri, anche attraverso qualsiasi programma terminale (hyperterminal)....
https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.9
quì c'è il repository per la versione 0.9g di GRBL....
jcnc è distribuito da jtronics...
http://www.jtronics.de/software/jcnc-cnc-steuerung.html
UniversalGcodeSender, è scritto in java....
https://github.com/winder/Universal-G-C ... /downloads
comunque linko la 1.0.5
http://www.dmxpassion.altervista.org/va ... -all32.rar
Poi c'è anche ...
GRBL Controller
Poi c'è anche ...
gcodeteleporter
e sicuramente altri ancora......
GRBL fino alla 0.8
GRBL 0.9
Poi c'è anche ...
GRBL Controller
Poi c'è anche ...
gcodeteleporter
- Garkoll
Ciao turbina,
è un pò che leggo e seguo i post su arduino e cnc.
Sicuramente il potenziale è tanto e vedo che hanno fatto passi avanti anche su questo mondo.
Ora ti volevo chiedere visto che sei uno dei pochi del forum che lo utilizzano e fanno esperimenti se avevi provato mach3 con arduino.
Ho letto a riguardo ma non sono ancora riuscito a famir un'idea se la scelta è valida o meno.
tu cosa ne pensi?
tu cosa ne pensi?
In teoria si potrebbe fare con arduino LEONARDO, questo perchè ha un mega32U4 che può essere programmato come periferica HID riconosciuta da mach3, in pratica è un lavoro che nessuno vuole fare perchè alla fine questo valido motion controller per mach3 verrebbe a costare i 5-10 euro di leonardo e lo potrebbe fare chiunque diminuendo tutti i guadagni provenienti dalle numerose schede motion controller oggi presenti sul mercato, attualmente il MC per mach3 che costa meno è questo:
https://www.cncitalia.net/forum/viewtopi ... 13#p542613
Appunto l'alternativa è GRBL con arduino UNO che però non viene riconosciuto come HID ma come VCOM e quindi funziona con un terminale e costa ancora meno , circa 3 euro
http://it.aliexpress.com/item/high-qual ... 80366.html
http://it.aliexpress.com/item/1PCS-UNO- ... 70021.html
- Garkoll
http://www.machsupport.com/forum/index. ... ic=21105.0
Io non sono affezionato a mach3 figurati, mi interessa solo perché questo ho imparato ad usare sia sul tornio che sulle 2 cnc.
ho visto anche planet e colibrì, tutto va bene basta che faccia quello che mi interessa.
Siccome sono ormai diversi anni che uso tutte le mie macchine con pc fisso+parallela+gecko e non ho mai avuto problemi sto pensando di passare ad usb e qui entra in gioco arduino perché open, solo per motivi di spazi e togliere 3 pc uno per ogni macchina..
Arduino UNO in quel caso è programmato non come motion controller ma come MODBUS Slave attraverso la VCOM , serve per espandere l'I/O di mach3 visto che la porta parallela del pc ha solo 17 I/O (5In e 12Out)
- Garkoll
Grazie turbina ottimo!
Voglio vedere GRBL ho un amico smanettone di arduino se mi aiuta provo a farci un pensiero.
Dirò una cosa epr cui i fulmini mi colpiranno... ma la devo dire
per mia diretta esperienza non comprare le copie cinesi di arduino, più di una volta mi hanno dato problemi e infine arduino nasce diciamo per star nella cameratta di uno smanettone... in ambienti non proprio sani richiede diverse precauzioni....
Non ho avuto grossi problemi con i compatibili, arduino è nato per essere replicato, la sainsmart (cinese) ha rifatto il disegno del PCB di arduino mettendo un chip nuovo , il CH340 che costa meno e va bene lo stesso, l'unico problema l'ho avuto in uno dI 10 PRO-MINI che il processore era saldato male
- Garkoll
Si anche io infatti mi riferisco a saldature fatte male o componenti a volte di qualità inferiore.
Dai se provo ti aggiorno e semmai ti disturbo per chiederti dei consigli..
- mapopower
Grande Turbina
ps.sarebbe anche ora che vengo a trovarti...dato che ho solo 10 min di strada
ho seguito con interesse la tua cnc arduino grbl, ne ho costruita una e ho provato vari software con jcnc ho dei problemi nel senso che a volte mi si blocca il programma, quindi ne ho provati tanti altri tra cui universal Gcode sender, e altri... poi ho trovato questo:
http://cnccontrol.byethost13.com/
il manuale è solo in spagnolo, che per me è come una seconda lingua e comunque è molto simile all'italiano, è quello con cui mi sono trovato meglio e con cui non ho problemi o almeno per ora non ne ho avuti.
Come cam ho provato sia cambam che il vecchio freemill, che blendercam, quest'ultimo nonostante sia troppo simile a blender che personalmente odio, ha degli ottimi tutorial online e delle discrete strategie per quel poco che devo fare io ovviamente. Ho riscontrato che con universal gcode sender e il gcode che creavo con freemill o con cambam, i motori si muovevano lentissimamente, per farli andare a velocità normale, ho dovuto cancellare le prime riche del listato gcode, mentre con cnc control anche con le prime righe il tutto andava alle velocità che avevo settato. Credo che questo problema sia dovuto alla mia ignoranza di base sul gcode, per scoprire la soluzione ci ho messo 3 giorni, cosa che forse per chiunque con un minimo di conoscenze di gcode avrebbe necessiatato 30 secondi.
Grazie comunque per avermi dato l'ispirazione per seguire questa strada che mi piace moltissimo.
