questo è quello che mi esce:
**** Connected to COM5 @ 115200 baud ****
Grbl 1.1h ['$' fr help]
$0 = 10 (Step pulse time, microseconds)
$1 = 25 (Step idle delay, milliseconds)
$2 = 0 (Step pulse invert, mask)
$3 = 0 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 1 (Status report options, mask)
$11 = 0.010 (Junction deviation, millimeters)
$12 = 0.002 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$200
$21 = 0 (Hard limits enable, boolean)
$22 = 0 (Homing cycle enable, boolean)
$23 = 0 (Homing direction invert, mask)
$24 = 25.000 (Homing locate feed rate, mm/min)
$25 = 500.000 (Homing search seek rate, mm/min)
$26250
$27 = 1.000 (Homing switch pull-off distance, millimeters)
$30 = 1000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$320
$100 = 5.697 (X-axis travel resolution, step/mm)
$101 = 4.717 (Y-axis travel resolution, step/mm)
$102 = 250.000 (Z-axis travel resolution, step/mm)
$110 = 500.00 (X-axis maximum rate, mm/min)
$111 = 500.000 (Y-axis maximum rate, mm/min)
$112 = 500.000 (Z-axis maximum rate, mm/min)
$120 = 10.000 (X-axis acceleration, mm/sec^2)
$121 = 10.000 (Y-axis acceleration, mm/sec^2)
$122 = 10.000 (Z-axis acceleration, mm/sec^2)
$10 = 200.000 (Status report options, mask)
$131 = 20.000 (Y-axis maximum travel, millimeters)
$132 = 200.000 (Z-axis maximum travel, millimeters)
ok
>>> $G
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
ok
[Error] Error while processing response <<Idle|MPos:0.000,0.000,0.000|FS:,0>>: empty String
<Idle|MPos:0.000,0.000,0.000|FS:0,0
[Error] Error while processing response <<Idle|MPos:0.000,0.000,0.000|FS:0,>>: Index 1 out of bounds for length 1
[Error] Error while processing response <<Idle|MPos:0.000,0.000,0.000|FS:00>>: Index 1 out of bounds for length 1
[Error] Error while processing response <<Idle|Mos:0.000,0.000,0.000|FS:00>>: Index 1 out of bounds for length 1
[Error] Error while processing response <<Idle|MPos:0.000,0.000,0.000|FS:0,|Ov:100,100,100>>: Index 1 out of bounds for length 1
[Error] Error while processing response <<Idle|MPo:0.000,0.000,0.000|FS:,0>>: empty String
Idle|MPos:0.000,0.000,0.00|FS:0,0|WCO:12.463,18.868,-1.000>
[Error] Error while processing response <<Idle|MPos:0.00,0.000,0.000|FS:0,>>: Index 1 out of bounds for length 1
Idle|MPos:0.000,0.00,0.000|FS:0,0>
[Error] Error while processing response <<Idl|MPos:0.000,0.000,0.000|FS:0,>>: Index 1 out of bounds for length 1
[Error] Error while processing response <<Idle|MPos:0.000,0.000,0.000|FS:,0|Ov:100,100,100>>: empty String
**** Connection closed ****
Pendant URL: http://192.168.1.78:8080
