Impostazione velocità motori
Sezione dedicata a Mach3
toff26
Messaggio da toff26 » mercoledì 15 maggio 2019, 9:34
Buongiorno, ho acquistato una cnc made in China e questi sono i parametri del motore. Qualcuno potrebbe aiutarmi per le impostazioni su mach3? Cosa devo mettere in steps.. velocity.. e Acceleration?
Sliding unit:
X axis:SFU1605 Ball Screws;
Y axis:SFU1605 Ball Screws;
Z axis:SFU1204 Ball Screws
Drive unit:
X axis:ø20 High intensity round rail,
Y axis: SBRø20 high-strength aluminum base rails;
Z axis: ø12 high-strength round rail
Stepping motor:two-phase 3A (with hand wheels)
Driving Power for Stepping motor:AC220V,240W, Output DC24V10A
Maximum Idle speed:1500mm/m
Working Speed:50-1500mm/min (different material with different speed settings)
Spindle motor:2200W high-speed variable frequency spindle motor, ER11 chuck , matching 6mm bur
Variable-frequency Drive(VFD):AC220V, 2200W, 0-400Hz(built-in Control box )
(tips:1,The spindle motor must connect with the VFD.2,It cannot directly connect with the supply voltage (AC110V/220V).3,Please don’t change the data setting of the VFD if you are not professional technicians, or it might damage the spindle motor.)
Drive of Stepping motor 0-3.5A adjustable four-axis drive(TB6560AHQchip, 24V power supply, 2,4,8,16Subdivision settings, Factory
setting:8subdivided)
Repositioning precision:≤0.05mm
Speed:0-24000r/m
Cooling method:Water cooling,Matching heat dissipation water pump
Spindle precision:Radial runout≤0.03mm
Carving command:G code/TAB file/nc/TAB /NCC/file
Protection:Emergency stop button
Recommend software:Mach3, EMC2
Communication interface:through USB PORT connect with computer
Software environment:Windows XP / win7 with 32bite(proper computer system makes the software run , otherwise it will not)
Input Volts: AC220V
Gross weight of machine :About 145kg/320lb
Update function: with limit switch
Torna a “Mach3”
