il mio CN vuole le velocità F (feed) in Mt/min ma sebbene imposti all'utensile
i Mt/min a 0,6 il postprocessor manda fuori il file con F 600 e non F 0.6
Potete aiutarmi??
Fabio
Ciao!Simone.A variable specification has the following format
[V|O|S|F|m]
Where
V = Variable name e.g. X or ZH.
S = String to print before value when output.
O = @ if value always output.
# if only output if value has changed since
last time value was output.
F = Format string. This controls the number of
decimal places, leading zeros etc. and is
documented later.
m = Scaling factor - a floating point number by which
variable is multiplied before formatting is applied.
