Messaggio
da tittopower » giovedì 1 ottobre 2020, 18:57
Sul sito ufficiale arduino-store si legge:
If you used Arduino Nano in your projects in the past, the Nano Every is a pin-equivalent substitute. Your code will still work, and you will NOT need to re-wire those motors you planned in your original design. The main differences are: a better processor, and a micro-USB connector.
ed inoltre
The Arduino Nano Every is an evolution of the traditional Arduino Nano board, but features a lot more powerful processor, the ATMega4809. This will allow you to make larger programs than with the Arduino Uno (it has 50% more program memory), and with a lot more variables (the RAM is 200% bigger).
Quindi dovrebbe essere assolutamente compatibile ed anche migliore.
MF30 - 1991 Inverter &
Ceriani 203 Norton - 1996 Inverter &
XJ25 CNC - 2013 &
Prusa I4 2016 &
Little Laser 2019 &
CNC-PCB 2019 -
http://www.tittopower.it/
