ho guardato bene il manuale i cicli fissi si possono scrivere come quelli del fanuc
J* Tapping Retract Speed (Rev. 10.13 and above)
Codice: Seleziona tutto
Code Group Function
G00* 01 Rapid Positioning Motion (X,Y,Z,A,B)(Setting 10, 56, 101)
G01 01 Linear Interpolation Motion (X,Y,Z,A,B,F)
G02 01 Circular Interpolation Motion CW (X,Y,Z,A,I,J,K,R,F)
G03 01 Circular Interpolation Motion CCW (X,Y,Z,A,I,J,K,R,F)
G04 00 Dwell (P) (P =seconds"."milliseconds)
G09 00 Exact Stop, Non-Modal
G10 00 Programmable Offset Setting (X,Y,Z,A,L,P,R)
G12 00 Circular Pocket Milling CW (Z,I,K,Q,D,L,F)
G13 00 Circular Pocket Milling CCW (Z,I,K,Q,D,L,F)
G17* 02 Circular Motion XY Plane Selection (G02 or G03) (Setting 56)
G18 02 Circular Motion ZX Plane Selection (G02 or G03)
G19 02 Circular Motion YZ Plane Selection (G02 or G03)
G20* 06 Verify Inch Coordinate Positioning (Setting 9 will need to be INCH) (Setting 56)
G21 06 Verify Metric Coordinate Positioning (Setting 9 will need to be METRIC)
G28 00 Machine Zero Return Thru Reference Point (X,Y,Z,A,B) (Setting 108)
G29 00 Move to location Thru G28 Reference Point (X,Y,Z,A,B)
G31** 00 Feed Until Skip Function (X,Y,Z,A,B,F)
(G codes continued next page)
Code Group Function
G35** 00 Automatic Tool Diameter Measurement (D,H,Z,F)
G36** 00 Automatic Work Offset Measurement (X,Y,Z,A,B,I,J,K,F)
G37** 00 Automatic Tool Offset Measurement (D,H,Z,F)
G40* 07 Cutter Compensation Cancel G41/G42/G141 (X,Y) (Setting 56)
G41 07 2D Cutter Compensation Left (X,Y,D) (Setting 43, 44, 58)
G42 07 2D Cutter Compensation Right (X,Y,D) (Setting 43, 44, 58)
G43 08 Tool Length Compensation + (H,Z) (Setting 15)
G44 08 Tool Length Compensation - (H,Z) (Setting 15)
G47 00 Text Engraving (X,Y,Z,R,I,J,P,E,F) (Macro Variable #599 to Change Serial Number)
G49* 08 Tool Length Compensation Cancel G43/G44/G143 (Setting 56)
G50* 11 Scaling G51 Cancel (Setting 56)
G51** 11 Scaling (X,Y,Z,P) (Setting 71)
G52 12 Select Work Coordinate System G52 (Setting 33, YASNAC)
G52 00 Global Work Coordinate System Shift (Setting 33, FANUC)
G52 00 Global Work Coordinate System Shift (Setting 33, HAAS)
G53 00 Machine Zero XYZ Positioning, Non-Modal
G54* 12 Work Offset Positioning Coordinate #1 (Setting 56)
G55 12 Work Offset Positioning Coordinate #2
G56 12 Work Offset Positioning Coordinate #3
G57 12 Work Offset Positioning Coordinate #4
G58 12 Work Offset Positioning Coordinate #5
G59 12 Work Offset Positioning Coordinate #6
G60 00 Uni-Directional Positioning (X,Y,Z,A,B) (Setting 35)
G61 13 Exact Stop, Modal (X,Y,Z,A,B)
G64* 13 Exact Stop G61 Cancel (Setting 56)
G65** 00 Macro Sub-Routine Call
G68** 16 Rotation (G17,G18,G19,X,Y,Z,A,R) (Setting 72, 73)
G69* 16 Rotation G68 Cancel (Setting 56)
G70 00 Bolt Hole Circle with a Canned Cycle (,I,J,L)
G71 00 Bolt Hole Arc with a Canned Cycle (,I,J,K,L)
G72 00 Bolt Holes Along an Angle with a Canned Cycle (,I,J,L)
G73 09 High Speed Peck Drill Canned Cycle (X,Y,A,B,Z,I,J,K,Q,P,R,L,F) (Setting 22)
G74 09 Reverse Tapping Canned Cycle (X,Y,A,B,Z,R,J,L,F) (Setting 130, 133)
G76 09 Fine Boring Canned Cycle (X,Y,A,B,Z,I,J,P,Q,P,R,L,F) (Setting 27)
G77 09 Back Bore Canned Cycle(X,Y,A,B,Z,I,J,Q,R,L,F) (Setting 27)
G80* 09 Cancel Canned Cycle (Setting 56)
G81 09 Drill Canned Cycle (X,Y,A,B,Z,R,L,F)
G82 09 Spot Drill / Counterbore Canned Cycle (X,Y,A,B,Z,P,R,L,F)
G83 09 Peck Drill Deep Hole Canned Cycle (X,Y,A,B,Z,I,J,K,Q,P,R,L,F) (Setting 22, 52)
G84 09 Tapping Canned Cycle (X,Y,A,B,Z,R,J,L,F) (Setting 130, 133)
G85 09 Bore in~Bore out Canned Cycle (X,Y,A,B,Z,R,L,F)
G86 09 Bore in~Stop~Rapid out Canned Cycle (X,Y,A,B,Z,R,L,F)
Code Group Function
G87 09 Bore in~Manual Retract Canned Cycle (X,Y,A,B,Z,R,L,F)
G88 09 Bore~Dwell~Manual Retract Canned Cycle (X,Y,A,B,Z,P,R,L,F)
G89 09 Bore~Dwell~Bore out Canned Cycle (X,Y,A,B,Z,R,L,F)
G90* 03 Absolute Positioning Command (Setting 56)
G91 03 Incremental Positioning Command (Setting 29)
G92 00 Set Work Coordinate Value (Fanuc) (HAAS)
G92 00 Global Work Coordinate System Shift (Yasnac)
G93 05 Inverse Time Feed Mode ON
G94* 05 Inverse Time Feed Mode OFF/Feed Per Minute ON (Setting 56)
G95 05 Feed Per Revolution
G98* 10 Canned Cycle Initial Point Return (Setting 56)
G99 10 Canned Cycle "R" Plane Return
G100 00 Mirror Image Cancel
G101 00 Mirror Image (X,Y,Z,A,B) (Setting 45, 46, 47, 48, 80)
G102 00 Programmable Output to RS-232 (X,Y,Z,A,B)
G103 00 Limit Block Look-a-head (P0-P15 for number of lines control looks ahead)
G107 00 Cylindrical Mapping (X,Y,Z,A,Q,R)
G110 12 Work Offset Positioning Coordinate #7
G111 12 Work Offset Positioning Coordinate #8
G112 12 Work Offset Positioning Coordinate #9
G113 12 Work Offset Positioning Coordinate #10
G114 12 Work Offset Positioning Coordinate #11
G115 12 Work Offset Positioning Coordinate #12
G116 12 Work Offset Positioning Coordinate #13
G117 12 Work OffsetPositioning Coordinate #14
G118 12 Work Offset Positioning Coordinate #15
