postprocessor modifica drilling
Sezione dedicata al Cad/Cam.
Artcam
JECK
Messaggio da JECK » sabato 17 agosto 2019, 18:47
buon giorno a tutti.
Volevo chiedervi se era possibile aggiungere al mio Postprocessor la possibilita di inserire l'uso del foratore:
G100 Foro Verticale ( utensili 1\10 )
G182 Foro Lato Sinistro ( utensili 17 \ 19 )
G183 Foro Lato Destro ( utensili 18 \ 20 )
G184 Foro Lato Posteriore ( utensile 21 )
G185 Foro Lato Anteriore ( utensile 22 )
ho provato ad aggiungere delle istruzioni ma non ha funzionato, vi allego il file, spero mi possiate aiutare grazie.
allego il file
POST_NAME = "Masterwood ATC Arc (mm) (*.prg)"
FILE_EXTENSION = "prg"
UNITS = "MM"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0|0.001]
VAR FEED_RATE = [F|C|F|1.0|0.001]
VAR X_POSITION = [X|C|X|1.2]
VAR Y_POSITION = [Y|C|Y|1.2]
VAR Z_POSITION = [Z|C|Z|1.2|-1]
VAR X_HOME_POSITION = [XH|A|X|1.2]
VAR Y_HOME_POSITION = [YH|A|Y|1.2]
VAR Z_HOME_POSITION = [ZH|A|Z|1.2|-1]
VAR ARC_RADIUS = [Radius|A|R|1.2]
VAR PLUNGE_RATE = [E|C|E|1.0|0.001666]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"|1 [TP_FILENAME]"
"|2 0"
"|3 1"
"|4 [XLENGTH]"
"|5 [ZLENGTH]"
"|6 [YLENGTH]"
"|7 0 0 0 0"
"|8 0"
"|9"
"|10"
"|11"
"|12"
"|13"
"|14"
":[TP_FILENAME]"
"G120 K1 "
"#910=DX"
"#911=DY"
"(Tool: [TOOLNAME])"
"(Tool Number: [T])"
"[13][10]"
"G172 [X] [Y] [Z] [S] [E] [F] T25/[T]"
+ Commands output at toolchange
begin TOOLCHANGE
"[13][10]"
+ Commands output for rapid moves
begin RAPID_MOVE
"G172 [X] [Y] [Z]"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"G101 [X] [Y] [Z] [F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"G101 [X] [Y] [Z]"
+ Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"G103 [X] [Y] [Radius] [F]"
+ Commands output for clockwise arc move
begin CW_ARC_MOVE
"G103 [X] [Y] [Radius]"
+ Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"G102 [X] [Y] [Radius] [F]"
+ Commands output for counterclockwise arc move
begin CCW_ARC_MOVE
"G102 [X] [Y] [Radius]"
+ Commands output at the end of the file
begin FOOTER
darkgt1983
Re: postprocessor modifica drilling
Messaggio da darkgt1983 » giovedì 29 agosto 2019, 23:14
Se questi codici sono scelti in base a qualche tua opzione devi usare un cam che sfrutti le variabili altrimenti aspire o artcam non possono fare al caso tuo per questa funzione aggiuntiva che sicuramente vorrai scegliere tu in base a ciò che dovrai fare a ogni lavorazione
solidcam e solidworks fino ad ora non esiste di meglio per me.
JECK
Messaggio da JECK » venerdì 30 agosto 2019, 13:51
Grazie per avermi risposto. Volevo chiederti, ho visto che per esempio su Aspire cè la possibilità di usare il foratore. Ed infatti quando genera i codici iso con opzione foratore, ad inizio istruzioni inserisce "DRILL" e numero utensile, ma viene assegnato a G172 e G101 che sono movimenti di pantografo. Ho pensato che nel postprocessor mancasse un'istruzione che indirizza la funzione DRILL al giusto comando iso. Potresti spiegarmi come posso fare. Ti ringrazio tantissimo
darkgt1983
Messaggio da darkgt1983 » venerdì 30 agosto 2019, 19:26
Nella sezione drill troverai se specificato i vari codici tipo G81-G83 se vuoi cambiare i codici da te menzionati si può Fares saranno solamente statici e non potranno essere scelti da te, per farlo dovresti usare unaltro cam che usa le variabili
JECK
Messaggio da JECK » venerdì 30 agosto 2019, 22:34
Ma secondo te, visto che Aspire ha una sezione DRILL ma l'unica condizione che mi da è la scelta del numero della punta " tool " T Non è possibile associarlo ad un G100 ( foro singolo )?
In Aspire è presente una funzione che ti permette di importare da una cartella vari file dxf con diverse geometrie, ed in maniera automatica associare tutte le lavorazioni su tutti i pezzi senza dovere aprire uno ad uno tutti i file, risparmiando un sacco di tempo. Sai per caso quale altro cam lo può fare, usando anche le variabili DRILL di cui mi parlavi
darkgt1983
Messaggio da darkgt1983 » venerdì 30 agosto 2019, 23:40
Assolutamente no non è possibile farlo con questi cam purtroppo
JECK
Messaggio da JECK » sabato 31 agosto 2019, 13:41
Neanche con CAM più complessi è possibile avere dei processi automatici ?
darkgt1983
Messaggio da darkgt1983 » sabato 31 agosto 2019, 14:59
Certo che con altri cam più professionali lo puoi fare tranquillamente
Torna a “Cad/Cam”
