formattare scheda pcmcia
- paolob66
Re: formattare scheda pcmcia
AT THE MS-DOS COMMAND PROMPT(FOUND UNDER ACCESSORIES)
TYPE IN, WITHOUT THE QUOTES,CHANGING THE DRIVE LETTER AS REQUIRED: "FORMAT E: /FS:FAT /A:64K", THEN PRESS ENTER TO EXECUTE COMMAND.
THE FORMATTING PROGRESS SHOULD BE INDICATED WITH AN INCREASING PERCENTAGE UNTIL DONE.
IF THE PC PROMPTS TO CONTINUE WITH FORMATTING, TYPE IN "Y".
Prova in questo modo
Buon lsvoro
Buon lsvoro
